Has anyone a good way to resolve the unknown associations that must be removed before deleting a user group?
  • May 16, 2014
  • 4 replies
  • 2370 views
These messages are a bane to me when removing legacy users or user groups, I had a similar issue with removing contacts when they were tied to unknown devices, but found i could easily retrieve that information with a custom object to get all contacts for all devices, but for user groups associated to Actions (or triggers? Does this mean Rules?) I have yet to find a slick solution:
I have had a look at mentor.axeda.com to see if i have grab all my Actions/Rules in one go, but there doesn't seem to be any properties for their user group associations, i also had a look at the user group classes but also did not see what i was looking for,
Any idea's on an easy way to resolve these would be gratefully received!
Many Thanks,
Alan
Best answer by kholbrook
Sorry, here are the imports:
import com.axeda.drm.sdk.action.Action
import com.axeda.drm.sdk.action.ActionFinder
import com.axeda.drm.sdk.user.UserGroup
Howdy Alan,
I have poured over the API docs, and I am afraid that there is not enough Action support in there to solve your problem.
The UserGroup that you assigned these Actions to is easy enough to find, but there is limited support for finding Actions. Now, it will be possible to do this with a little bit of coding. I threw together some pseudo-code here:
ActionFinder finder = new ActionFinder()
List<Action> actions =  finder.findAll()
def userGroups = new ArrayList<UserGroup>()
actions.each() { action ->
    // these are the Lists of UserGroups you care about:
    userGroups.addAll(action.userGroupsForEdit)
    userGroups.addAll(action.userGroupsForExecute)
// remove the dupes
userGroups = userGroups.unique()
// iterate and look for your UserGroup
userGroups.each() { ug ->
    if (ug.name == "group you want to delete") {
        // remove this group from the Actions
ablyth10-MarbleAuthor
Hi Kevin,
Thanks so much for this, I must be missing an import unfortunately as i can't resolve the class, from mentor.axeda.com I made some educated guesses as to which class might contain the elusive ActionFinder, but have had to come back ask which would be correct? Our platform is 6.6,
unable to resolve class Act­ion­Fin­der
@ line 13, column 14.
Code snippet (I planned to iterate through them all, to validate all the associations):
import java.util.*;
import groovy.xml.MarkupBuilder
import org.custommonkey.xmlunit.*
import com.axeda.services.v2.*;
def writer
def xml
try
ActionFinder finder = new ActionFinder();
writer = new StringWriter()
xml = new MarkupBuilder(writer)
xml.root()
   for (ac in actions)
kholbrook1-VisitorAnswer
