Hey,I am just doing simply the TWX Rest Api Call from a very simple java code.
What I want is that just simply pass a variable from Java code to TWX service and just want to check that is that value is coming in TWX or not,then I will have some other work with that variable.
I just wrote a simple code and establish the connection with my Local TWX and tried to pass that String value named "id".
And then on TWX side, I just created a thing and created a service and take an input parameter named "id" and simply did "logger.warn(id);" in script editor.
And after running that Java code on Eclipse, I am getting 400 Error (i.e. some forbidden request error) on Eclipse and on TWX, in the Logs I am getting
"[context: com.thingworx.webservices.context.HttpExecutionContext@66efd9][message: Invalid Invocation Request]" this error.
My Java Code is :
package Call;
import java.io.OutputStream;
import java.net.HttpURLConnection;
import java.net.URL;
import java.nio.charset.Charset;
public class TWRestCallSample
public static void main(String[] args)
try { callTW("RowId_2"); // dummy id value }
catch (Exception e) { e.printStackTrace(); }
static void callTW(String id) throws Exception
String statusMsg = "";
try {
String uri ="http://localhost:8080/Thingworx/Things/test/ServiceDefinitions/test1?appKey=d77e8e3a-209f-44ea-8a2f-6ee88c6cf0c7";
System.out.println(uri);
HttpURLConnection conn = (HttpURLConnection) new URL(uri).openConnection();
conn.setDoOutput(true);
conn.setRequestMethod("POST");
conn.setRequestProperty("Content-Type","application/json;charset=UTF-8");
OutputStream os = conn.getOutputStream();
os.write(id.getBytes(Charset.forName("UTF-8")));
os.flush();
System.out.println("1");
if (conn.getResponseCode() != HttpURLConnection.HTTP_OK) {
statusMsg = conn.getResponseCode() + " " + conn.getResponseMessage();
throw new RuntimeException("Failed : HTTP error code : " + statusMsg);
System.out.println("2");
os.close();
conn.disconnect();
catch (Exception e){
throw new Exception(statusMsg + "." + e);
And on TWX Side, I just created Thing->test and in that the service->test1 and in the service Input/Output Parameter is "id" of String type.
If you get any idea why is this happening then please tell me.
I got stuck there too hard.
Thanks.
