How can I localize Thing properties?
  • March 31, 2017
  • 3 replies
  • 2040 views
When I display Thing properties using Value Display or Label widget, how can I localize value? It seems that Value Display widget does not accept localize token. Label widget accepts Localize Token, However, when it is bound to property of Thing,  the property do not seem to be treated as Localization token.
Best answer by posipova
Currently it's not supported, however, there is a Jira for this.
Please see the following article for a possible workaround https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS252326&lang=en_US
posipova20-TurquoiseAnswer
20-Turquoise
March 31, 2017
shasegawa1-VisitorAuthor
Thank you for the helpful information.
Have a look at my updated Value Display widget post, Localised (or Localized) Value Display Widget
HTH
Wayne
