How do I Bind multiple things from C SDK
  • December 2, 2015
  • 2055 views
I am developing TW agent using C SDK which will collect data from multiple assets connected to gateway. Each asset is different. Hence I want to treat it as separate thing. Now agent initializes, I can register each different thing and its properties separately. Can I then call twApi_BindThing for each different thing e.g. twApi_BindThing(thing1), twApi_BindThing(thing2) etc and then call twApi_Connect(CONNECT_TIMEOUT, twcfg.connect_retries); to connect to the server. I assume that each thing will shown as connected on Server. This sort of functionality is possible in ready EMS server. But I want to do it similarly using C SDK.
Please confirm above approach is correct OR suggest solution if wrong.
Regards
Satish
Hello Satish,
What you described is the correct approach.  Call twApi_BindThing() once for each thing you want to register.
-Mike
