How do I change a widget Property in Code
  • July 14, 2015
  • 839 views
For instance I want to change a textbox's read only status from within a service.  The text box readonly property doesn't have an input or output on the mashup like some other properties do.  I tried something like this first
me.textbox-10.ReadOnly=false;
but this failed as the textbox-10 nomenclature caused an error,  which leads me to believe there is some other ID  for textbox-10
    If this functionality that you want to use, I recommend with this widget code at its basis, customize and create your own widget that allows binding to that property.
