How do I know which version of ThingWorx is stable?
  • March 7, 2017
  • 4348 views
I have come across several (diverse) issues with the ThingWorx Platform which seems mainly related to the H2 version, but I have also found problems with the PostgresSQL version.
I always use Ubuntu 14.04 LTS since it is certified and the prescribed versions of Java, Tomcat and PostgresSQL.
I appreciate that there is a lot of development and we all contribute towards logging issues and squashing bugs.
However, when needing to deploy a production build, how do we know which version and combinations of Java / Tomcat / OS is MOST stable?
This becomes even more challenging if we start adding extensions and the EMS.
I would appreciate some guidance or even a rule of thumb if someone has found one that is reasonably reliable.
Thanks!
Not for now,
We had been stick on 6.5.13 for one year and a half, and doing a lot of tests in order to move on 7.X for 6 months - starting at 7.0, we expect to move on 7.3.3 when it's released....
Neither 6.5.13 on Neo4j was super stable, Yesterday we moved on 6.5.3 PostgreSQL
Carles.
Do11-VisitorAuthor
Thanks Charles,
Can you elaborate on OS, PSQL, Tomcat and Java versions that you are running on 6.5.3?
Well we are on TW Cloud Services, then I don't know, I suppose the recomended ones.
On my local tests ( Development, Testing and Performance Tuning - I know Windows XP x64 it's not supported but it works and starts in a sweep 😞
Performance Tests on Migration from 6.5.13 Neo4j to 7.X PostgreSQL
Hardware Configuration:
  • Virtual Machine
    • Oracle VM VirtualBox
    • 3Gb RAM
    • 1CPU ( no CPU Cap )
    • Enable I/O APIC ON
    • Paravirtualization Interface: Legacy
    • Hardware Virtualization: ON Enable Nested Paging
    • No Encryption
  • Host Machine
    • MacBook Pro ( 8.2 )
    • Intel Core i7-2675QM
    • CPU 2,2Ghz <-> 3,1Ghz
    • 1 CPU x 4 Cores
    • 16Gb RAM ( 1333Mhz DDR3 )
    • HD: Samsung SSD 850 EVO 500Gb over SATA
      • HFS+ with register
      • No encryption
Software Configuration:
  • Virtual Machine
    • Windows XP x64 SP2
  • Host Machine
    • Mac OS X El Capitan 10.11.6
Configuration 1: TW 6.5.13 + Neo4j
Operation Configuration:
  • Java 1.8.0.112-b15
    • Configuration:
      • -Dd64
      • -Dfile.encoding=UTF-8
      • -Xms2g
      • -Xmx2g
      • -XX:+UseG1GC
  • Tomcat 8.0.39
  • Neo4j 2.1.8
  • ThingWorx
    • Logging
      • ApplicationLog = WARN
      • CommunicationLog = WARN
      • ConfigurationLog = INFO
      • ScriptLog = INFO
      • SecurityLog = WARN
Configuration 1: TW 6.5.13 + PostgreSQL
    • Configuration:
      • -Dd64
      • -Xms2g
      • -Xmx2g
      • -XX:+UseG1GC
  • Tomcat 8.0.39
  • PostgreSQL 9.4.10
  • Rhino Version 1.7R5
  • ThingWorx
    • Logging
      • ScriptLog = INFO
Configuration 2: TW 7.2.6 + Neo4j
    • Configuration:
      • -Dd64
      • -Xms2g
      • -Xmx2g
      • -XX:+UseG1GC
  • Tomcat 8.0.39
  • Neo4j 2.1.8
  • ThingWorx
    • Logging
      • ApplicationLog = INFO
      • ScriptLog = INFO
Configuration 3: TW 7.3 + PostgreSQL
    • Configuration:
      • -Dd64
      • -Xms2g
      • -Xmx2g
      • -XX:+UseG1GC
  • Tomcat 8.0.39
  • PostgreSQL 9.4.10
  • ThingWorx
    • Logging
      • ScriptLog = INFO
