How to create Application Key and Get Key ID in Java Thingworx
  • January 10, 2017
  • 1910 views
Hi All,
I am trying to create Application Key and Get Key ID inside Custom Authenticator Code using Java. How to do that ?
22-Sapphire I
January 11, 2017
The Authenticator should be able to invoke CreateApplicationKey in the Thingworx platform in the Resources/EntityServices
With that you have for the User the following services
DoesApplicationKeyWithKeyIdExist
GetApplicationKeyExpirationInfo
With that you should be able to do it.
