How to display location data from two columns in a Map ?
  • November 18, 2016
  • 2086 views
I am trying to display two locations in a map , but when I try to bind the second location data in a map it replaces the previous data .
How can I display both of the locations ?
You should be able to bind an infotable of locations. You just need an infotable property with a data shape that has one location type field. Then import GetPropertyValues service on your mashup and bind the infotable to the map. Hope this helps!
done111-VisitorAuthor
Hi Tori,
Thanks for your answer . But the problem is that I want to display Point of Interests but it replaces the binding of the current location.Any help ?
I am not sure I know what you mean by your last comment. Can you elaborate?
