How to dynamic add properties by using JAVA Edge SDK
  • December 9, 2015
  • 2 replies
  • 2094 views
Hi all,
I check JAVA sample code, and it use ThingworxPropertyDefinitions to push properties to ThingWorx.
If I want to add a new properties in ThingworxPropertyDefinitions at runtime, how can I achieve this...?
Thank you.
@ThingworxPropertyDefinitions(properties = {
  @ThingworxPropertyDefinition(name="Temperature", description="Current Temperature", baseType="NUMBER", category="Status", aspects={"isReadOnly:true"}),
  @ThingworxPropertyDefinition(name="Pressure", description="Current Pressure", baseType="NUMBER", category="Status", aspects={"isReadOnly:true"}),
  @ThingworxPropertyDefinition(name="FaultStatus", description="Fault status", baseType="BOOLEAN", category="Faults", aspects={"isReadOnly:true"}),
  @ThingworxPropertyDefinition(name="InletValve", description="Inlet valve state", baseType="BOOLEAN", category="Status", aspects={"isReadOnly:true"}),
  @ThingworxPropertyDefinition(name="TemperatureLimit", description="Temperature fault limit", baseType="NUMBER", category="Faults", aspects={"isReadOnly:false"}),
  @ThingworxPropertyDefinition(name="TotalFlow", description="Total flow", baseType="NUMBER", category="Aggregates", aspects={"isReadOnly:true"}),
Best answer by VladimirRosu_116627
Hi Brandon,
See below a snippet (I tested a value received from XML to see if is number, boolean or string and created specific property per type):
Also note at the end the use of super.initialize(); instead of super.initializeFromAnnotations() (you can either use one or another as I've seen)
                         PropertyDefinition pd;
                        AspectCollection aspects = new AspectCollection();
                        if (NumberUtils.isNumber(str_AttributeValue)) {
                            pd = new PropertyDefinition(str_AttributeName,
                                    " ", BaseTypes.NUMBER);
                        } else if (str_AttributeValue == "true"
                                | str_AttributeValue == "false") {
                                    " ", BaseTypes.BOOLEAN);
                        } else
                                    " ", BaseTypes.STRING);
                        aspects.put(
                                Aspects.ASPECT_DATACHANGETYPE,
                                new StringPrimitive(DataChangeType.VALUE.name()));
                        // Add the dataChangeThreshold aspect
                        aspects.put(Aspects.ASPECT_DATACHANGETHRESHOLD,
                                new NumberPrimitive(0.0));
                        // Add the cacheTime aspect
                        aspects.put(Aspects.ASPECT_CACHETIME,
                                new IntegerPrimitive(0));
                        // Add the isPersistent aspect
                        aspects.put(Aspects.ASPECT_ISPERSISTENT,
                                new BooleanPrimitive(true));
                        // Add the isReadOnly aspect
                        aspects.put(Aspects.ASPECT_ISREADONLY,
                        // Add the pushType aspect
                        aspects.put("pushType", new StringPrimitive(
                        aspects.put(Aspects.ASPECT_ISLOGGED,
                        pd.setAspects(aspects);
                        super.defineProperty(pd);
                        super.initialize();
Hi Brandon,
                        } else
                        aspects.put(
                        super.initialize();
byang11-VisitorAuthor
Hi Vladimir,
Thanks for your reply, this method works.
But I have one more question, I want to push a table like below structure to ThingWorx by using JAVA SDK.
Bind the table data to PieChart and then display it.
How do I define the table and pass value?
NameValue
fieldName15
fieldName210
fieldName315
