How to get remote property definition.
  • December 21, 2015
  • 2 replies
  • 2454 views
Hi All,
I am trying to get the remote properties of a remote thing. I want to do it programmatically (using services.). To see what are the properties are available at remote thing. Then i can bind or unbind it as per requirement. We can do it in composer by manage binding -> remote tab. I want to see remote properties using service.
Thanks in advance!!!
Vishal Vaidya
Best answer by mattl1
You can use GetRemoteMetadata:
// result: JSON
Things[ThingName].GetRemoteMetadata();
ThingName ​should have a Thing Template of 'RemoteThing' in order to see the GetRemoteMetadata service. The service returns JSON, which can then be iterated through:
var remoteData = Things[ThingName].GetRemoteMetadata();
var propertyDefinitions = remoteData.propertyDefinitions;
for(var i in propertyDefinitions)
    propertyDefinitions.name;     //Available remote property name
mattl11-VisitorAnswer
// result: JSON
vvaidya1-VisitorAuthor
Thank a lot Matt Lang​. This exactly i was looking for.
Thanks again!
Vishal Vaidya
