How to get rid of SAXParserError using getXML() call?
  • March 20, 2016
  • 2 replies
  • 3051 views
Being new to ThingWorx I´m trying to follow an example to retrieve data using the code:
var params = {
  proxyScheme: undefined /* STRING */,
  headers: undefined /* JSON */,
  ignoreSSLErrors: undefined /* BOOLEAN */,
  useNTLM: undefined /* BOOLEAN */,
  workstation: undefined /* STRING */,
  useProxy: undefined /* BOOLEAN */,
  withCookies: undefined /* BOOLEAN */,
  proxyHost: undefined /* STRING */,
    url: "http://www.thingworx.com/feed" /* STRING */,
  timeout: undefined /* NUMBER */,
  proxyPort: undefined /* INTEGER */,
  password: undefined /* STRING */,
  domain: undefined /* STRING */,
  username: undefined /* STRING */
// result: XML
var xmlPage = Resources["ContentLoaderFunctions"].GetXML(params);
var params = {
    infoTableName : "InfoTable",
    dataShapeName : "ThingWorxFeedData"
var result = Resources["InfotableFunctions"].CreateInfoTableFromDataShape(params);
for each (var item in xmlPage.channel.item){
    var row = new Object();
    row.title = item.title;
    row.link = item.link;
    result.AddRow(row);
where ThingWorxFeedData is a defined existing DataShape.
When I test the service the error message below is the result:
Error executing service
Wrapped org.xml.sax.SAXParseException; lineNumber: 2; columnNumber: 10; DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true. Cause: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
Please advise, what do I do now?
I´m running ThingWorx in a browser over VPN to a SI installation in our local office.
The url "http://www.thingworx.com/feed" has been removed. So, please use other rss feed to get your job done. I recommend you to use google news feed instead since that is pretty persistent and its url is "https://news.google.com/news/feeds".
And you used same variable name "params" twice. I recommend you not to use duplicate variable names in one script.
Daniel
Me too getting a same error.
HoweverWrapped org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 10; DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true. Cause: DOCTYPE is disallowed when the feature "http://apache.org/xml/features/disallow-doctype-decl" set to true.
However I ran run my web services through SOAPUI without any issues.
Having trouble here in thingworx.
