How to get the logs in a file format?
  • May 4, 2017
  • 2 replies
  • 2524 views
How to get the all my custom log details  in a file format?
    20-Turquoise
    May 4, 2017
    Could you please clarify what you mean by "custom log details"?
    You may find your application logs in ThingworxStorage/logs directory.
    Hi Bavithraa Marimuthu​,
    I hope that by custom logs you are referring to the Script logs which are generated when any service runs in ThingWorx composer.
    They are available at <Root>/ThingworxStorage/logs/ScriptLog.log
    I hope it helps.
    May 5, 2017
    In <Root>/ThingworxStorage/logs/ScriptLog.log, it has the info of all logs. But I want only my defined (custom) logs to be captured that too in a file format Eg: xxxx.log
    How can I do this ?
    One option could be to create a custom service and use GetLogEntries Service of ScriptLog entity and then filter based on the requirement.
    Then we can use Data Exporter widget to export the log data to a file in a ThingWorx repository.
    I hope it helps.
