how to open the links in the server
  • May 31, 2017
  • 2 replies
  • 2706 views
hi ,
  I have already used GetFileListingWithLinks in the Service and it returns downloadLinks of all the files.
  now want to open downloadLinks of the files in my server.  is it possible to do it? how to do?
Wlihua could elaborate where exactly you wish to do it i.e. from a mashup or you want it to be done in the background via a service?
wlihua1-VisitorAuthor
yes, i wan it to be done in the background(server) not in a mashup.
could you please describe a little more on the use case i.e. what exactly are you planning to do achieve using those links in the background? is it just for downloading the files? or do you intend to perform certain action on those files?
You can check the Timer Thing which fires an event after certain interval and based on that you can execute the service. But i'm not really sure what you intend to do with the URLs
I want to download the files immediately when I get all downloadLinks in the server . Not in a mashup to click to download them.
