How to perform search operation row wise on a Data table or infotable in the mash up display screen
  • April 3, 2017
  • 2 replies
  • 1361 views
Hi all,
I have a requirement in mind where my input is data in form of data table, I want to perform field wise search on each row element of that table, How can that be done? Also which widget must be used to do the same?
    As you say your source of data is datatable you may use Querydatatableentries snippet for various filter criteria && , or etcc  , as long as you are thinking on mashup side filter search you can use datafilter widget and use the same service which queries the datatable
    Hi vemuri srilekha​,
    There are two options:
    1. Query the Data in the Service itself and pass the output to Grid. We can bind the changed event to request the updated data as soon as the filter is updated.
    2. Use Data Filter widget as Nilesh told and filter the data based on it.
