Feb 7, 2024 12:36 PM UTC
How To Set Group in runtime through service under Resources->InfotableFunctions-> Services->TOJSON
I Want to set group name programmatically through service of Resources->InfotableFunctions-> Services->TOJSON
I need standard service code to do programmatically.
Please check the below screen shot
Feb 8, 2024 10:51 AM UTC
I have implemented code similar to this, but getting error of push related as shown in below image.
from where data is getting in permissions highlighted below in bold
currentPermissions.permissions.push(newPermissions)
Pls send me root cause o this issue
Feb 7, 2024 12:58 PM UTC
@MM_10159448 ,
I think this post should help you: https://community.ptc.com/t5/ThingWorx-Developers/How-to-AddRuntimePermission-for-PlatformSubsystem-amp/td-p/727025
In summary, run GetRuntimePermissionsAsJSON, append your own permissions to it, and then run SetRuntimePermissionsAsJSON
- Nick
Feb 7, 2024 1:34 PM UTC
Thank you for your reply,
I have viewed your provided link and code but in that code , Code is getting permission and then setting runtime permission for all who is falling under
but my requirement is , I want to set group name for runtime for particular service only 'Resources->InfotableFunctions-> Services->TOJSON'(to this service only)
Please suggest any code for this
Feb 7, 2024 3:01 PM UTC
It would look something like this:
// result: JSON
var currentPermissions = JSON.parse(Resources["InfoTableFunctions"].GetRunTimePermissionsAsJSON());
var newPermissions = {
	"resourceName": "ToJSON",
	"EventSubscribe": [],
	"PropertyWrite": [],
	"PropertyRead": [],
	"ServiceInvoke": [{
		"isPermitted": true,
		"name": groupToAdd,
		"type": "Group"
	"EventInvoke": []
currentPermissions.permissions.push(newPermissions);
Resources["InfoTableFunctions"].SetRunTimePermissionsAsJSON({
	permissions: currentPermissions /* JSON */
Where groupToAdd is the name of the group you want to give access to that service.
-- Nick
