6-Contributor
November 11, 2014
How to set property of implementing thing based on event.
  • November 11, 2014
  • 2 replies
  • 1035 views
h3. Hi All,
I have two different things (A and B). I want to subscribe a event of thing A (Thing Template) and based on that event i want to set property of Thing B.<br><br>
I have created two subscription in B thing template for testing<br>1. On data change event of a property defined in thing A <br>2. On a custom event. <br><br>
To test it i have created a mash up where i am manually setting the property of Thing A. In turn it should change the value of property in Thing B.<br>But it is not working. <br><br>
Kindly help me out. if i am missing something.<br>Thanks in advance!!!<br><br>
Regards,<br>Muzahid<br>
<br>
    Hi Muzahid, what does your subscription script look like?
    Also you can add a logger statement to your subscription to make sure that it is actually firing.
    6-Contributor
    November 12, 2014
    Hi Pai,
    Thanks for the response. Now it is working and logger is good way to debug.
    Muzahid
