How to uninstall the failed installation on Thingworx foundation 8.3 trial version
I have exactly the same issue. Can you please send me the uninstaller file as well. Let me try that, otherwise I will have to reinstall my Windows OS it seems....
Subh
@slangley wrote:
Hi @Newtepos.
I am forwarding the uninstaller from my local system via email.  I don't have confidence that it will work for you, but you are welcome to try it.
This file gets generated in {drive}:....\twxFoundationH2Trial-8.3.2 folder.  Not sure if that folder still exists on your machine since you cancelled out.
--Sharon
@slangley wrote:
Hi @Newtepos.
--Sharon
Support
Hi @Subhankar.
I sent a private email with the uninstaller.  Since this file is generated during the installation process based on your selections, I do not expect it to work.
--Sharon
Hello  Subhankar,
Please refer below link for accepted solution of this issue.
https://community.ptc.com/t5/ThingWorx-Developers/How-to-uninstall-the-failed-installation-on-Thingworx-foundation/m-p/594650#M34340
Also accept this reply as a solution, if worked-out for you.
Thank-you.
