I am facing a problem with using customized styles in navigation widget.
  • February 9, 2017
  • 4 replies
  • 2687 views
When I use my own styles in navigation widget then it is picking the default styles of navigation and not my custom styles. When I refresh the mashup it picks the default navigation styles.
Priyanshi Saxena​, Which ThingWorx version are you on? Can't reproduce it on my local instance 7.3.1
And also are you using +custom option for custom style or creating a style definition first and using it in your mashup.
psaxena1-VisitorAuthor
Hi Ankit,
I amusing Thingworx 6.6 and yes I created the style using +Custom .
Hello Priyanshi Saxena​,
Have you set your custom StyleDefinition in the Navigation widget configuration? Which version of the Thingworx do you use?
Hi Jakub,
Yes I have set the custom style in the widget also. I am using Thingworx version 6.6 and the problem specially exists with Navigation Hover style.
