In Menu, default check box is not reflecting in mashup
  • June 9, 2017
  • 2 replies
  • 4302 views
As I used the Menu entity in my mashup.Even if checked the default option in menu its still not reflecting in my Mashup.
Please help us on the above issue.
20-Turquoise
June 9, 2017
Which version of Thingworx are you using?
ad241-VisitorAuthor
I am using Thingworx 7.4 version
Hi Aakash D24​,
Just to make sure your Menu or SubMenu items contains Mashup, Hyperlink or logout? Just Menu with Menu sub-items will not show in Mashup.
ad241-VisitorAuthor
Hi Ankit Gupta
I have mashup in my menu and i have marked it as default but still its not reflecting I dont know why its happening no clue on it.Please help regarding it is there a procedure to use the menu item with default part
Hi Aakash D24​,
Can you please attach your entities here to help me check?
