Is there any way to dual-purpose a slider widget?
  • November 21, 2017
  • 1117 views
I want to be able to resize the model with a slider and switch the slider's purpose to rotate the model with a toggle button.
    22-Sapphire I
    November 21, 2017
    Not sure if you are doing this in Thingworx platform, but if so, you can take the value of the slider and combine that with the value of the toggle to determine what actions should be taken.
