Issues with alert acknowledgement and alert history
Hello all, earlier I asked a question about Alert History and it was confirmed that if I want to acknowledge multiple alerts (>10) on a "thing" entity, "AlertHistory" stream would not be able to capture that Choosing the most appropriate data storage method. Can anyone suggest a way around this problem? The only solution I can come up with is to use a data table instead. However, the question arises how to generate a unique key for each entry from each "thing" (concurrency problem). Thank you for your suggestions!
