Java Based ThingsShape
  • August 30, 2015
  • 3020 views
Hi
I am trying to create a sophisticated Java based ThingShape, which contains several services.
In one of those services, i would like to read the value of one of the properties,
which were defined in the ThingShape, and were received their value from the implemented Thing.
The only workaround i was able to find, is to use ThreadLocalContext.getMeContext() inside the service,
which return the Thing which implements that ThingsShape, and which fire the ThingShape's service,
and then iterate over it's properties.
Can you please confirm that this is the Bast practice for getting the Thing which call the ThingShape's service?
Thank you
Ido
I'd also be interested to know if this is the recommended method.
Hi
The best I can say is that I received code for an example ThingShape from PTC Tech Support which used that technique to get the Thing.
Regards
Ian
Thanks, Ian. I am going to give this a try.Any chance you could share the ThingShape sample from PTC?
