Java extension SDK serialization
I was working on a cache system for Thingworx, done directly from the java SDK. The matter is that no Thingworx class is Serializable !
Not all classes should be, of course, but all the "result" classes as Infotable (and all needed subclasses) should be.
The other problem is that these classes or the classes they use are often final.
This means that if you want to serialize an Infotable, you have to create an entire set of objects that would be the serializable counterparts of the non serializable Thingworx objects. And that represents a lot of classes !
My question is : Will you make these classes serializable so that we can do stuffs like a cache system without re-coding the entire Thingworx API ??
Thanks a lot !
