Java keystore error 'Input not an X.509 certificate' during trial Thingworx foundation installation
I'm following the install documentation for thingworx foundation and I get to the step where I need to create a self-signed certificate. Unfortunately my Java keystore won't except the certificate that is created. It is rejected with this error > java.lang.Exception: Input not an X.509 certificate"
I've tried this solution https://community.ptc.com/t5/ThingWorx-Developers/keytool-error-java-lang-Exception-Input-not-an-X-509-certificate/td-p/623652 but the thingworx foundation installer won't accept the certificate file created.
Any ideas?
slangleyAnswer
Support
Hi @Chris-P.
This article may be helpful.  In addition, you can bypass SSL during the initial installation and configure it after you have validated that ThingWorx is running successfully.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @Chris-P.
--Sharon
Chris-P4-ParticipantAuthor
Hi Sharon,
Thanks for your suggestion, it works as far as resolving that certificate error, but when I start thingworx foundation by going to https://localhost:8443/Thingworx in chrome an unsafe connection warning is shown. I can login and connect to Thingworx but the connection is unsecure.
Chris
