Javascript return
  • April 24, 2015
  • 2 replies
  • 1874 views
I am working on a local service. I want to put in a check for undefined infotable input. The code below fails to save because of the return. Does anyone have any suggestions on how should I can trigger the return of my service if this check fails?
if (typeof newDataInfotable == "undefined"){
    logger.warn("data infotable was empty");
    return;
    } else {
    //put all the code here}
    What I do in most cases is creating a flag and checking all conditions like this:
    var valid = true;
    valid = false;
    if ( //another checking ) {
    valid = false;
    valid = false;
    if ( valid ) {
    //here I put my code when all conditions are fulfilled
    I've discovered another way with javascript of doing it:
    labelName:
          // -- your code
          break labelName; // -- it will jump until the end of the braquets.
         // -- other conditional code
