Json error
  • March 25, 2016
  • 2 replies
  • 3434 views
we are trying to get the content from the url using POSTJSON service. used the below code:
var params = {
  proxyScheme: undefined /* STRING */,
  headers: undefined /* JSON */,
  ignoreSSLErrors: undefined /* BOOLEAN */,
  useNTLM: undefined /* BOOLEAN */,
  workstation: undefined /* STRING */,
  useProxy: undefined /* BOOLEAN */,
  withCookies: undefined /* BOOLEAN */,
    proxyHost: undefined /* STRING */,
  url: "https://public-api.wordpress.com/rest/v1/sites/www.davidjmcclelland.com/posts/" /* STRING */,
  content: undefined /* JSON */,
  timeout: undefined /* NUMBER */,
  proxyPort: undefined /* INTEGER */,
  password: undefined /* STRING */,
  domain: undefined /* STRING */,
  username: undefined /* STRING */
// result: JSON
var result = Resources["ContentLoaderFunctions"].PostJSON(params);
But we are getting the error while running the service.
The error is given below :
Error executing service
Wrapped java.net.UnknownHostException: public-api.wordpress.com Cause: public-api.wordpress.com
Aditya Kumar
Please help us with the error
Aditya, what version of ThingWorx are you using? There was a fix released recently on versions 6.5.8, 6.6.3 and 7.0.1 regarding not getting any header information back when using PostJSON; but you still should not be getting the error message you're currently seeing. I tested this out on 6.5.9, and I didn't get any errors.
March 29, 2016
Hi Ravi,
We are using 6.5.0 version.
Aditya Kumar
March 30, 2016
Is this a problem of proxy or what, due to which i am getting an error?
Is there a way to bypass the proxy or the host exception?
Aditya
You would need to use GetJSON to get the contents. Are you getting an error when using that as well?
