Label chart style
  • December 1, 2017
  • 2 replies
  • 1490 views
I've applied a style to a label with a background as blue color and foreground as white color.  when i drag a new lable its coming bydefault with same style, if i remove the style apply new, its applicable to previous label as well. how to independently style two labels in a same layout?Screenshot (43).png
    You may have inadvertently edited the default label style. If you select “edit” when you click on a style, you’re changing that style across the whole platform. Two ways you can go about using different styles. 1, you can create a style (I’ll usually find the default style for that widget, duplicate it, and make necessary changes and save it under a new name). 2, remove the style from the widget, click on the wand on the right side of the style box, and choose ‘Custom’ style.
    dnagda1-VisitorAuthor
    It's working now... Thanks alot
