Location values are rounded up after 4th place after decimal
  • July 10, 2017
  • 4 replies
  • 2360 views
I am using the same code to incorporate data in property, but when i check my location is getting only 4 digits after decimal point, for example - 10.11012734  is sent to property as 10.1101 can you please tell why is it happening?
Message was edited by: Sushant Pandey : branched from https://community.thingworx.com/thread/39200?sr=inbox&ru=13756
Swaraj, where do you see this effect? Are you observing this in a Data Grid widget on a Mashup?
sostwal1-VisitorAuthor
We are facing this issue while inserting the data from property to datatable.
Regards
Swaraj
Do you see this effect prior to insertion or after? How are you viewing the values? Did you create mashup with a Grid to display the values?
