Logout and redirect to Form Login
I have a very basic problem and found some articles and threads about it, but none seems to solve the issue.
I want to create a simple logout in a mashup which redirects the user back to the Thingworx form login. I am using Thingworx 9.2.1 and the standard "Logout" mashup function. The form login isn't a standard mashup so I am using the URL redirect.
Problem is: When I redirect to <hostname>/Thingworx/FormLogin/MyOrg the user can access Thingworx again without entering his username/password. This does not happen if I redirect to a different site (like google.com). But I can see that the user session is terminated in both cases.
I saw this article which try to explain the behaviour, but I did not understand it. And it's basically saying the exact opposite of that what I am observing.
Did I miss something obvious here?
slangleyAnswer
Support
Hi @DanZ.
There is a fix coming for this issue in the following ThingWorx releases:
9.0.14
9.1.9
9.2.5
I'll let you know once these releases are made available.
--Sharon
@odukiya Could you please help with this?
P.S. A similar question was previously: https://community.ptc.com/t5/ThingWorx-Developers/Creating-Multiple-User-Login-in-Thingworx/m-p/706905
slangleyCommunity ManagerAnswer
Support
Hi @DanZ.
9.0.14
9.1.9
9.2.5
--Sharon
