Mail Thing Issues
  • July 9, 2014
  • 6 replies
  • 2940 views
I have a mail thing setup and I have the account information entered as described in the workbook, however I am receiving the follow error:
Unable to Send Message: Could not connect to SMTP host: smtp.gmail.com, port: 25
Any help would be appreciated.
Thank you,
Mike Francek
    Hi Mike,
    Are you connecting from within your corporate network? If so, the port may be blocked.
    Adam,
    I am connecting from within my corporate network. Is there a way around the port being blocked or do I need to get with my IT department?
    Thank you,
    Mike
    Hi Michael,
    I had the same problem and in the end I had to connect through a different network in order to connect to the smtp host.
    You can do three things:
    1. contact your IT and ask them to open access for that smtp.gmail.com on port 25
    OR
    2. ask them what open ports you can use to connect to smtp.gmail.com
    OR
    3. create a local mail server on your laptop using the hMailServer software. In this case you will change the server address to localhost.
    Best regards,
    Vladimir
