Mashup flashing while redirecting
  • August 7, 2017
  • 2550 views
Hi Folks,
I have a Home Mashup for the FormLogin Mashup (Thingworx built-in) and as per logic it should be loaded for the first time.And whenever user login again,that home Mashup shouldn't be loaded but some other Mashup.In simple words,Whenever user login second or more time,he/she should be redirected to another page instead of that Home Mashup.
For this, I'm checking User's login status if its first time or not and redirecting accordingly. It redirecting the user but whenever user login for the second time,that Home Mashup flashes for a second before getting to the desired page.
Example: Whenever User logs-in Thingworx composer for the first time,he/she sees a Terms and Conditions pop-up and second time it redirects directly to Composer.I want exactly this to be implemented.
Tarun
Create a new mashup that just does the redirect ( the first time to the Terms and conditions, and the other times to the real Home Mashup ), this new mashup kind be kind of "Loading..." or splash screen alike.
TanmeyTWX17-PeridotAuthor
Hi Carles,
This is not possible in my case.
To validate if user need to be navigated to either of the Mashups,need to have some history of TermsConditions Page for that User and if we implement your above strategy,it will load before TermsConditions page always and for the first time,for that User.
Yes but this is a splash screen page ( can be just a Loading... text ), where it's the problem?
