Mashup Navigation
Hi all,
I'm trying to have a 3-way navigation in a main mashup, based on a parameter through the URL. I have DB services to look for the parameter and get the respective Mashup name, which is bound to the navigation widget. When I test the services separately they work, but in the mashup, I get a "Not found" error, as if one of the parameters of the services is not being sent correctly.
I hope you can help me,
Thank you.
