menu default problem
I made a master mashup which contains a vertical menu on the leftbar. In my menu definition, I checked first item as default and left the remaining 3 items default unchecked. everything works ok. but when I switched order of the first two menu items (dragged the first item below the second item) and changed default as the new first menu item and unchecked the new second item, the result is still showing my original default which was my old first item is displayed. I cannot seem to change to a new default no matter what I do. any suggestions?
