NG Composer feature availability
  • June 8, 2017
  • 7 replies
  • 9587 views
Use this document as a guideline on what is available in the Next Gen Composer and what is still best done in the legacy Composer.
Feature Available in Release
Entity Editing
Projects 7.4.0
Depends On 8.1.0
Edit Entities (Entity Management) TBD
Things 7.4.0
Data Table 7.4.0
Streams 7.4.0
Value Streams 7.4.0
Blogs 7.4.0
Wikis 7.4.0
Thing Templates 7.4.0
Thing Shapes 7.4.0
Data Shapes 7.4.0
Model Tags (Vocabulary and Terms) 7.4.0
Industrial Connectors 7.4.0
Integration Connectors 7.4.0
Application Keys 7.4.0
Subsystems 8.0.0
Resources 8.0.0
        Change History 8.1.0
        Mashups 8.1.0
Base Type Editors
Avatar 7.4.0
Basetype Name 7.4.0
Blob 7.4.0
Boolean 7.4.0
Dashboard Name 7.4.0
Datashape Name 7.4.0
Date 7.4.0
Date Time 7.4.0
File Repository 7.4.0
Group Name 7.4.0
GUID 7.4.0
HTML 8.0.0
Hyperlink 7.4.0
Image 7.4.0
Image Link 7.4.0
Infotable 7.4.0
Integer 7.4.0
JSON 7.4.0
Location 7.4.0
Long 7.4.0
Mashup Name 7.4.0
Menu Name 7.4.0
Notification Content Name 7.4.0
Notification Definition Name 7.4.0
Number 7.4.0
Password 7.4.0
Persistence Provider Name 7.4.0
Persistence Provider Package 7.4.0
Project Name 7.4.0
Query 7.4.0
String 7.4.0
Tag 7.4.0
Text 7.4.0
Thingcode 8.0.0
Thing Name 7.4.0
Thing Shape Name 7.4.0
Thing Template Name 7.4.0
Time Span 7.4.0
User Name 7.4.0
Value Stream 7.4.0
Vec2, Vec3, Vec4 8.0.0
XML 7.4.0
Property and Alert Management
Property Editing (CRUD) 7.4.0
Duplicate (Individual Properties) 8.0.0
Manage Bindings (Dialog) 7.4.0
Set Values
Add Alert from Property List 7.4.0
Alert Editing (CRUD) 7.4.0
Anomaly Alert 8.0.0
        Notifications 8.1.0
Service Management
JavaScript Editing 7.4.0
SQL Query and Command Editing 8.0.0
Route Editing (Connectivity End-Points) 7.4.0
Remote Service Editing 8.0.0
         Remote Service Binding 8.1.0
Generic Service Viewing 8.0.0
Code-Completion for Properties, Services and Events 8.0.0
Code Linting for JavaScript Services 8.0.0
Code Validation for JavaScript Services 7.4.0
Code Snippets 7.4.0
"Me" and Entities Code Insert 8.0.0
Ability to Save and Execute Tests while Editing 8.0.0
Ability to Save and Continue to Edit Service 8.0.0
Ability to store Test input parameters across test execution 8.0.0
Ability to view JSON service output in test execution 8.0.0
Ability to view embedded Info-Tables in test execution with drill-down behavior 8.0.0
Provide Light and Dark editing themes for JavaScript Editing 7.4.0
Find and Replace including REGEX statements 7.4.0
Events
Event Editing (CRUD) 8.0.0
Subscription Management
Subscription Editing (CRUD) 7.4.0
JavaScript Editing (CRUD) 7.4.0
Configuration Tables
Single Row Configuration Table Edit and Update 7.4.0
Multi Row Configuration Table edit and Update 8.0.0
Mashup Builder
        Embedded Mashup Builder 8.1.0
Import / Export
         Import from File 8.1.0
All other Import features 8.2
Export 8.3
Entity Editors
         Masters  8.2
         Gadgets 8.2
Dashboards 8.2
Menus 8.2
Media 8.2
Style Definitions 8.2
State Definitions 8.2
Mashups 8.2
User Groups  8.3
Users  8.3
Organizations  8.3
Directory Services 8.2
Authenticators 8.2
Localization Tables 8.2
Logs & Monitoring  8.3
Properties
Duplicate Multiple Properties 8.2
Create/Add Data Shapes to Remote Bound Infotables via Dialog 8.2
Service Management
Ability to Override Services 8.2
Code-Completion for Services and Events 8.2
"Me" and Entities Code Snippet Insert 8.2
Shared Configuration Tables 8.2
Permissions
Collection Permissions  8.3
Entity Permissions 8.3
You can detail this two features please:
Adding that editing and creating Users, User Groups and Organizations are supported only in the Legacy Composer at this time (v 8.0.0).
cbaldwin14-AlexandriteAuthor
Chris C. updated this to reflect.
Remote Service "editing" allows you to create a service which represents a service in your Remote Edge service implementation to execute within Composer.  You can specify the same name and arguments as your remote edge service.
Generic service viewing let's you see the services on the Generic Thing template.  An example would be GetPropertyValues service, you can now open to view the inputs, outputs, documentation.  You cannot see the implementation however.
Ok thanks, "Remote Service Editing" was too good to be true Imagine an Edge Agend which has Javascript embedded and you can program it from the platform...
Is the Monitoring section from the Old Composer planned to be integrated in the Next Gen Composer?
Hi Vlad,
From our engineering team:
For the 8.3 release of Next-Gen Composer in 2018, System Monitoring will be fully exposed within Next-Gen Composer.  Some of the monitors will be re-skinned versions of the existing monitors whereas others will be re-engineered.
We'll have more details as we near release.
