Observe Thingworx Property Change with Java SDK
  • February 1, 2017
  • 1844 views
Hi all,
I'd like to observe a specific property of my Thingworx Thing via Java SDK. Therefore I've created a Thingworx Client, which is connected to Thingworx. After this, I've created a Virtual Thing with my Thingname and added a propertyChangeListener. Unfortunately, the listener does not get fired, as soon as I change the property in Thingworx. Does anyone know where's the problem or where to find an example for this?
Here's my Code Snippet:
ClientConfigurator config = new ClientConfigurator();
config.setUri("http://xxx.xxx.xxx.xxx:8080/Thingworx/WS");
config.setAppKey("xxx");
config.ignoreSSLErrors(true);
try {
  TwxClient client = new TwxClient(config);
  client.start();
  boolean isConnected = client.waitForConnection(30000);
  System.out.println("Client is connected:"+isConnected);
  String thingName = "ThingWatcherThing";
  VirtualThing thing = new VirtualThing(thingName, "", thingName, client);
  thing.addPropertyChangeListener(new VirtualThingPropertyChangeListener() {
     @Override
     public void propertyChangeEventReceived(VirtualThingPropertyChangeEvent event) {
        Property property = event.getProperty();
        String name = property.getPropertyDefinition().getName();
        if(name.equals("TestProp") == false){
           return;
  client.bindThing(thing);
} catch (Exception e1) {
  e1.printStackTrace();
So, where's the problem? Is ist the correct approach?
Many Greets, Korbinian
Hi Korbinian,
Won't it be easier to create subscription to the data change event happening on the platform? There's something discussed about this on the community, please check this thread Extension : Thingworx Event Subscription
I think with Event and Subscribing to that event would be an efficient approach. Please do correct me if this is a wrong understanding
Hope this helps.
