Opening Master in Thingworx 5.4
  • March 6, 2015
  • 2 replies
  • 865 views
Hi
I have a DefaultPageMashup selected on my Master. When I try to open Master it does not open any mashup.
This feature was available in 4 version.
Is there a workaround?
Sabarish
    Sabarish,
    Are you opening the Master from Composer (i.e. 'View Mashup')? If so, you need to remove the extraneous "&mashup=". After removing this from the URL, your Mashup will load as expected.
    Adam
    sgobi1-VisitorAuthor
    Thanks Adam. That worked.
    Previously, the Link used to include the mashup as well.
    Now it is enough only if we give the link removing the &masup to the users.
