Pivoting infotable in grid
Hello guys,
I have seen this post.
https://community.ptc.com/t5/ThingWorx-Developers/infotable-pivot/m-p/608598#M36084
But I need a function that allows me to pivot an Infotable with only two columns, one of type number and one of type string.
Is there an easy possiblity to do so?
Support
Hi @etc6.
The general procedure is in the post you linked to.  Are you running into an issue?  You may have to provide your entities so we can gain a better understanding.
--Sharon
Support
Hi @etc6.
If you have found a solution to your question, please post a new reply with details of the solution and mark it as the Accepted Solution.  This will benefit others on the community with the same question.
--Sharon
