[POSTJson] model POSTJson
  • October 25, 2016
  • 9 replies
  • 7677 views
Hi guys !
I'm trying to join an extern API with Thingworx. I format my request with POSTMAN and now I want to use the snippet service PostJSON.
But I always had syntax issues with it.
var params = {
  proxyScheme: undefined /* STRING */,
  headers: undefined /* JSON */,
  ignoreSSLErrors: undefined /* BOOLEAN */,
  useNTLM: undefined /* BOOLEAN */,
  workstation: undefined /* STRING */,
  useProxy: undefined /* BOOLEAN */,
  withCookies: undefined /* BOOLEAN */,
  proxyHost: undefined /* STRING */,
  url: "https://api.netatmo.com/oauth2/token" /* STRING */,
  content: {
"grant_type":"password"
"client_id":"[YOUR_CLIENT_ID]"
"client_secret":"[YOUR_CLIENT_SECRET]"
"username":"[USERNAME]"
"password":"[PASSWORD]"
"/* JSON */,
  timeout: undefined /* NUMBER */,
  proxyPort: undefined /* INTEGER */,
  password: undefined /* STRING */,
  domain: undefined /* STRING */,
  username: undefined /* STRING */
// result: JSON
var result = Resources["ContentLoaderFunctions"].PostJSON(params);
Can you help me about how correctly use the syntax ?
Guillaume
22-Sapphire I
October 26, 2016
"/* JSON */,
seems to have " but no closing one, these items also seem placed rather strange.
gbeaumont1-VisitorAuthor
Finally, I changed my code for :
var contents={
    'Content-Type': 'multipart/form-data',
    'grant_type':'password',
    'client_id':'[YOUR_CLIENT_ID]',
    'client_secret':'[YOUR_CLIENT_SECRET]',
    'username':'[USERNAME]',
    'password':'[PASSWORD]'
var params = {
  url: 'https://api.netatmo.com/oauth2/token' /* STRING */,
  content: contents /* JSON */,
// result: JSON
var resultJson = Resources["ContentLoaderFunctions"].PostJSON(params);
var result = JSON.stringify(resultJson);
No more errors but when I test my service in TW the result is {"headers":"","error":"invalid_request"}
I don't understand why
Does the rest call work outside of ThingWorx, like have you verified the syntax of the actual API call in a browser?
I too have the same issue.  I used a packet trace application to see what was being sent to the REST server...
Postman sends just the content json that I specify in the body:
[{ "id": "Mytag.value", "v": "112"}]
however, the ContentLoaderFunctions for PostJSON sends :
{"array":[{"v":99,"id":"Mytag.value"}]}
When I change the body of my Postman call to match the Thingworx call, I get the same Invalid Request error from the REST server.  The params for the post is written as:
var params = {
//proxyScheme: undefined /* STRING */,
headers: headers /* JSON */,
ignoreSSLErrors: 1 /* BOOLEAN */,
//useNTLM: 1 /* BOOLEAN */,
//workstation: undefined /* STRING */,
useProxy: 0 /* BOOLEAN */,
withCookies: 0 /* BOOLEAN */,
//proxyHost: undefined /* STRING */,
url:  'http://192.168.248.128:39320/iotgateway/write' /* STRING */,
content:[{ "id":tagname, "v":input}] /* JSON */,  ....
This works - using PostText() to pass a JSON to Kepware IoT Gateway REST server:
var headers = {"authorization": me.MyServic(),
                         "content-type": "application/json",
                         "Accept":"*/*"
var data = JSON.stringify([
    "id":tagname,
    "v": input
var params = {
url:'https://192.168.248.140:39320/iotgateway/write' /* STRING */,
content: data /* JSON */,
timeout: 3000 /* NUMBER */
//  result: JSON
var result = Resources["ContentLoaderFunctions"].PostText(params);
* Set "content-type" to "application/json"
** Configure content data as a JSON
*** Use PostText() function.
22-Sapphire I
September 27, 2017
Great after that you can convert the response back to JSON I think ParseJSON should work? and work with the response as an object.
