Progress gauge import failed in TWX 9.1.0
Hi Team,
I tried to import the attached progress gauge extension (took from one of the community post) but it's not working for me. I am seeing below error in Application Log.
ERROR [widget] "CustomCSS" widget type is missing required member widgetProperties()
I am not sure how it worked for other user. I tried to clear browser cache, marking 'Enable Beta Mashup Features' to true in platformsubsystem configuration but still not working.
Can you please help me what need to be fixed here.
Krishna.
abjainAnswer
@Krish007 : I checked the extension attached here and it does not have a metatdata.xml file. I think you have taken from this post: https://community.ptc.com/t5/ThingWorx-Developers/Progress-gauge-import-failed-in-Thingworx-9-1/td-p/706522
Instead, can you please try downloading 'Progressgauge1.zip' extension from this post and import?
abjain15-MoonstoneAnswer
Support
Hi @Krish007
If the previous post helped to resolve your issue, please mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
