Proportional Chart
  • February 16, 2015
  • 2 replies
  • 1719 views
I'm trying to use the proportional chart, with dates on the x-axis and hours on the Y-axis.  When I run it, the date is not showing below (says invalid date), and the hours data is showing all in one column.  Any thoughts on why this would be happening?
    20-Turquoise
    February 16, 2015
    Please make sure your mappings are correct. For the Invalid Number issue, check your datashape field definitions and make sure the datetime property has a base type of "datetime". In your widget mapping,
      • XAxisLabelType set to "Date/Time"
    For the data showing all in one column, again make sure to map properly your data and datafield.
    • XAxisField has to have your datetime field selected.
    keriw1-VisitorAuthor
    It appears that you can't actually define the X-axis on a proportional chart.  I had everything configured correctly.  I ended up using the label chart instead and having to do a stacked series, which involved me having to pivot my table first.
    Keri
