QueryImplementingThingsWithData
  • April 27, 2017
  • 3264 views
good morning
I need to take some of the thing properties that are associated with a thing template.
I use QueryImplementingThingsWithData as shown below.
But in this way I get all the properties instead of me interests only one specification.
Can someone help me?
Example
Var params = {
MaxItems: undefined / * NUMBER * /,
NameMask: undefined / * STRING * /,
Query: undefined / * QUERY * /,
Tags: undefined / * TAGS * /
// result: INFOTABLE dataShape: RootEntityList
Var list = ThingTemplates ["ThingTemplate"]. QueryImplementingThingsWithData (params);
Thank you
Antonio, for further filtering on the data returned are you using the Query with that you can include AND/OR to filter out the result
Matches or NotMatches filter
var query =
    "filters": {
        "type": "Matches|NotMatches",
        "fieldName": "Source",
        "expression": "(Kettle)|(Filler)"
ad'orso-21-VisitorAuthor
Thank you for your answer.
Ok i know this feature
But I'm interested in taking all the values of the "fieldName": "Source"
Without "expression":
But if I do not write the expression goes wrong
And I also need to have the data of two fieldName" different
How can I do?
Antonio D'Orso​,
Per my understanding; you can either remove the columns using: InfotableName.RemoveField(fieldName);
Or create a new InfoTable and copy the required fields in that Infotable by using Infotable for loop snippet.
