QueryNamedPropertyHistory with Row Control/Limiting
  • April 7, 2016
  • 0 replies
  • 1363 views
Following on from my post QueryPropertyHistory Service with Row Control/Limiting, we incorporated this function in to a service which extends and adds the capability to specify Property names too, just like QueryNamedPropertyHistory.
We also created a similar service for QueryNamedPropertyHistoryRowLimited, below. This will need the additional input configuring for propetryNames, as per the default service QueryNamedPropertyHistory.
/* *** QueryNamedPropertyHistoryRowLimited *** */
//Does simple step-interpolation of a fixed number of points between startDate and endDate
//set default values for properties undefined
var ed = endDate;
var sd = startDate;
var mi = maxItems;
//if endDate is undefined, choose NOW as the endDate
if (ed == null) {
    ed = new Date();
//if startDate is undefined or greater than the endDate, choose 24 hours ago as the startDate
if ((sd == null) || (sd > ed)) {
    var dateValue = new Date();
    sd = dateAddHours(dateValue, -24);
//if maxItems is null or undefined, set to 100 rows of data as default
if ((mi == null) || (mi == undefined)) {
    mi = 100;
//calculate the time period between rows of data
var startUTC = Date.UTC(sd.getFullYear(), sd.getMonth(), sd.getUTCDate(), sd.getUTCHours(), sd.getUTCMinutes(), sd.getUTCSeconds());
var endUTC = Date.UTC(ed.getFullYear(), ed.getMonth(), ed.getUTCDate(), ed.getUTCHours(), ed.getUTCMinutes(), ed.getUTCSeconds());
var timeSlice = Math.round((endUTC -startUTC) / (mi - 1));
//setup the date for query on the first loop iteration
var loopDateUTC;
var count = 0;
//define the sort order, based on user selection
if(oldestFirst) {
    loopDateUTC = startUTC;
} else {
    loopDateUTC = endUTC;
//loop through for maxItems-1 iterations and get one row for the named properties each time
for (count=0; count < (mi); count++) {
    var loopDate = new Date();
    loopDate.setTime(loopDateUTC);
    var params = {
        oldestFirst: false /* BOOLEAN */,
        maxItems: 1 /* NUMBER */,
        endDate: loopDate /* DATETIME */,
        propertyNames: propertyNames /* INFOTABLE */,
        query: query /* QUERY */,
        startDate: undefined /* DATETIME */
    //if this is the first iteration, create the output table from the first result set
    if (count == 0) {
        //get one row of data to obtain the structure
        var outputTable = me.QueryNamedPropertyHistory(params);
        outputTable.RemoveAllRows();    //clear table rows for readding later
    //get one row of data to add to our table
    var propertyHistory = me.QueryNamedPropertyHistory(params);
    var row = propertyHistory.getRow(0);
    //set the datetime of the row to match the Query endDate
    row.timestamp = loopDate;    //because we know that timestamp will be our column name
    outputTable.AddRow(row);
     //prepare for next iteration
    if(oldestFirst) {
        loopDateUTC = loopDateUTC + (timeSlice);
    } else {
        loopDateUTC = loopDateUTC - (timeSlice);
var result = outputTable;
