Remote Thing properties value get reset everynight
  • November 17, 2016
  • 2900 views
Hi Guys!
I was using Java SDK to call a Thing service to create a remote thing, then bind it with my sdk and send data to it
Everything works fine and I can see remote thing data updating while I was running the sdk(jar file).
But even I already set all properties to persistent, every morning this remote thing still lose all data and roll back to just create status(because it shows last connection is 1969-12-31 19:00:00.000 )
Is there something I did wrong in my sdk to reset this remote thing everyday(I didn't run the jar file over night, i turn it off before i left office)?or is that some setting in Thingworx platform?
Thank you for any advice and idea!
Best
Liwei
Liwei, when does the property value reset? Is it after a Tomcat restart, SDK restart or a Thing restart?
liwei5-Regular MemberAuthor
Hi AanJan,
Thingworx Server is running on AWS, it shouldn't restart every night(I'm not 100% sure, but I do lost data overnight, in the day time I didn't seem to lose any data).
SDK restart will not reset all properties value.
I didn't try to restart Thing, will a Thing restart itself somehow?
It shouldn't restart on its own. I'm more curious as to why it resets at night only, as you said nothing happened in the day time. I assumed the SDK might reset/ overwrite it back to the default once you start it up, but you noted that the SDK restart does not reset all properties.
