Repeater loading issue
Hi, We are using contained mashup in a repeater. Based on the user input,different contained mashups are being called into the repeater. In this we are facing the issue that the page loads from the middle when the ItemLoadBehavior is set to Load/Unload or Load/ no Unload. When the ItemLoadBehavior is set to Load all then there is a loading problem. Please suggest a possible solution.Its urgent. Thanks, Aditya.
