Repeater widget performance solution
  • May 25, 2016
  • 871 views
As we know repeater widget has some performance issues,Can we use ThingShape Mashup or ThingTemplate Mashup instead of Static or Responsive Mashup , to overcome that issue.? and how to do it?
Quick Response appreciated.
Thanks.
Tarun, it would be dependent on your use case. How many rows are you rendering through the Repeater widget? What widgets are in use? What is the volume of data bound to it?
