Rickshaw Widget error in Combined.7.2.1-b71.20160815.034519.00564.js
Hey guys,
I try to implement a widget which will use rickshaw. My widget is realy simple currently:
TW.Runtime.Widgets.simpleRickshaw = function () {
this.renderHtml = function () {
var rickshowCode = this.getProperty("RickshawCode");
var html = '<div class="widget-content widget-simpleRickshaw">' +
'<script type="text/javascript" src="../Common/extensions/iSAX_Rickshaw/ui/simpleRickshaw/include/d3/d3.min.js"></script>' +
'<script type="text/javascript" src="../Common/extensions/iSAX_Rickshaw/ui/simpleRickshaw/include/rickshaw/rickshaw.min.js"></script>' +
'<link type="text/css" href="../Common/extensions/iSAX_Rickshaw/ui/simpleRickshaw/include/rickshaw/rickshaw.min.css" />' +
'<div id="chart"></div>' +
'<script>' +
rickshowCode +
'</script>' +
'</div>';
TW.log.debug("html:" + html);
return html;
this.afterRender = function() {
this.updateProperty = function(){
TW.log.debug("simpleRickshaw");
RickshowCode is a property of the widget where I insert the sample code of rickshaw:
var graph = new Rickshaw.Graph( {
element: document.querySelector("#chart"),
width: 300,
height: 200,
series: [{
color: 'steelblue',
data: [
{ x: 0, y: 40 },
{ x: 1, y: 49 },
{ x: 2, y: 38 },
{ x: 3, y: 30 },
{ x: 4, y: 32 } ]
graph.render();
If I test the widget with this code, I get an error in log:
15:35:15 INFO - deleted TW.mashupCache[mashupName]
15:35:16 DEBUG - simpleRickshaw
15:35:16 DEBUG - html:<div class="widget-content widget-simpleRickshaw"><script type="text/javascript" src="../Common/extensions/iSAX_Rickshaw/ui/simpleRickshaw/include/d3/d3.min.js"></script><script type="text/javascript" src="../Common/extensions/iSAX_Rickshaw/ui/simpleRickshaw/include/rickshaw/rickshaw.min.js"></script><link type="text/css" href="../Common/extensions/iSAX_Rickshaw/ui/simpleRickshaw/include/rickshaw/rickshaw.min.css" /><div id="chart"></div><script>var graph = new Rickshaw.Graph({ series: [ { data: [ { x: 0, y: 2 }, { x: 1, y: 4 }, { x: 2, y: 4 }]}], renderer: 'area', element: document.querySelector('#chart') }); graph.render();</script></div>
15:35:16 ERROR - An error occurred while calling simpleRickshaw::renderHtml, Id = "simpleRickshaw-17". Exception: nodes[0] is undefined on line number 3 in file Combined.7.2.1-b71.20160815.034519.00564.js line 634 > eval
Line 3 is the starting point of the combined...js and line 634 is the first line of jquery-1.11.0.min.js.
I'm not realy sure what the problem is and how to fix it.
