Run Time permissions to select and view Things
Hi, I've created a mashup with a Tree listing Things the user can select and view properties from. It's in the form
Location 1
VM1
VM2
Location 2
VM3
VM4
When I load the mashup as an Admin, I can see everything, and it works fine. However, when I load it as User 1, I get a red error bar in the Tree widget and none of the associated information can load to other widgets. User 1 is a member of Location1Organization, which has visibility on the Location and VMs. User 1 is also a member of Location1 group which has RunTime permissions for everything except PropertyWrite. Is there something else I'm missing in the permissions or somewhere else I need to control access?
Thanks!
