SSL configuration for Azure IoT Hub connector configuration
 I have enabled https configuration in server.xml in Tomcat folder. What are steps to follow in Azure IoT Hub configuration to enable the https? I am using Thingworx 8.5.1 version and IoT Hub 3.0.2.
I have added below configuration in environment variable. azre-iot service is not running if set below configuration. Azure IoTHub connector was working correctly without enable https and also receiving the data correctly from Azure IoT Hub to Thingworx. I have followed Thingworx help document.
"AZURE_IOT_OPTS=-Djavax.net.ssl.trustStore=
C:\Program Files\Apache Software Foundation\Tomcat 9.0\conf\cacerts-customized -Djavax.net.ssl.trustStorePassword=xxxxxxx"
Also, I have updated in conf. "platforms = "wss://localhost:443/Thingworx/WS"
Latha
vi1Answer
This issue resolved through support ticket. We have added SSL certificate into Java trust store. After that, its established connection between thingworx and azure IoT Hub.
Thank you
Latha
Hi @vi1
What is the error you are getting in cxserver.log file located at Azure-IoT-Hub-Connector-<ver>\connector\bin\ when you are trying to connect using SSL?
Sachin
vi116-PearlAuthor
Thank you for replay.
I am getting below error in cxserver log. what is the configuration in environment variable for ssl. Below is the configuartion in environment variable.
AZURE_IOT_OPTS=-Djavax.net.ssl.trustStore=C:\\Program Files\\Apache Software Foundation\\Tomcat 9.0\\conf\\cerificatename.pfx -Djavax.net.ssl.trustStorePassword=xxxxx
2021-04-12T01:52:01.779 [NettyClient-NIO-1] ERROR c.t.s.i.t.netty.NettyChannelHandler - [ClientHandler: b17106b7] WebSocket error: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target, closing connection!
io.netty.handler.codec.DecoderException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:468)
at io.netty.handler.codec.ByteToMessageDecoder.channelRead(ByteToMessageDecoder.java:276)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:379)
at io.netty.channel.AbstractChannelHandlerContext.invokeChannelRead(AbstractChannelHandlerContext.java:365)
at io.netty.channel.AbstractChannelHandlerContext.fireChannelRead(AbstractChannelHandlerContext.java:357)
at io.netty.channel.DefaultChannelPipeline$HeadContext.channelRead(DefaultChannelPipeline.java:1410)
at io.netty.channel.DefaultChannelPipeline.fireChannelRead(DefaultChannelPipeline.java:919)
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:163)
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:714)
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:650)
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:576)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:493)
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:989)
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74)
at java.lang.Thread.run(Thread.java:748)
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.ssl.Alert.createSSLException(Alert.java:131)
at sun.security.ssl.TransportContext.fatal(TransportContext.java:353)
at sun.security.ssl.TransportContext.fatal(TransportContext.java:296)
at sun.security.ssl.TransportContext.fatal(TransportContext.java:291)
at sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(CertificateMessage.java:652)
at sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(CertificateMessage.java:471)
at sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(CertificateMessage.java:367)
at sun.security.ssl.SSLHandshake.consume(SSLHandshake.java:376)
at sun.security.ssl.HandshakeContext.dispatch(HandshakeContext.java:444)
at sun.security.ssl.SSLEngineImpl$DelegatedTask$DelegatedAction.run(SSLEngineImpl.java:983)
at sun.security.ssl.SSLEngineImpl$DelegatedTask$DelegatedAction.run(SSLEngineImpl.java:970)
at java.security.AccessController.doPrivileged(Native Method)
at sun.security.ssl.SSLEngineImpl$DelegatedTask.run(SSLEngineImpl.java:917)
at io.netty.handler.ssl.SslHandler.runAllDelegatedTasks(SslHandler.java:1510)
at io.netty.handler.ssl.SslHandler.runDelegatedTasks(SslHandler.java:1524)
at io.netty.handler.ssl.SslHandler.unwrap(SslHandler.java:1408)
at io.netty.handler.ssl.SslHandler.decodeJdkCompatible(SslHandler.java:1235)
at io.netty.handler.ssl.SslHandler.decode(SslHandler.java:1282)
at io.netty.handler.codec.ByteToMessageDecoder.decodeRemovalReentryProtection(ByteToMessageDecoder.java:498)
at io.netty.handler.codec.ByteToMessageDecoder.callDecode(ByteToMessageDecoder.java:437)
... 16 common frames omitted
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:439)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:306)
at sun.security.validator.Validator.validate(Validator.java:271)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:312)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:275)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:140)
at sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(CertificateMessage.java:630)
... 31 common frames omitted
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.build(SunCertPathBuilder.java:141)
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:126)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:280)
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:434)
... 37 common frames omitted
Latha
@vi_01
Refer following help center guide, navigate to section When Using SSL/TLS and set the environment variable as mentioned there. Make sure that you do NOT use double quotation marks when setting the environment variable on Windows. If you use them, the Connector will fail to start.
Sachin
