SSL problems with MQTT and ThingWorx
Hello PTC,
I'e tried all the ways which are described in the forum, but I haven't got anything, I can't connect the MQTT Broker
with SSL enable(and works) with ThingWorx server. I'm using a 90 days version, and I don't know if the security configuration in the MQTT extension ca be enabled.
Thanks very much,
Carlos
tdixitAnswer
Hello @charlo
If you check the Point 3 "useSSL: Should ThingWorx use SSL when connecting to the MQTT broker?" in the article shared. It is mentioned to copy the cacerts file into jssecacerts and I can see the cacerts is present  at this C:\Program Files\Java\jre1.8.0_281\lib\security  location
Please copy the cacerts file into jssecacerts
  • Best practice is to not modify cacerts directly
  • The JVM will choose jssecacerts over cacerts on startup
and then Import the Self-Signed Certificate or the Custom Root Certificate into the jssecacerts truststore with the following command:
  • keytool -import -alias <Descriptive Alias> -file <Path To Certificate File> -keystore jssecacerts
  • Where
    • <Descriptive Alias>: Any identifier that will help identify the entry. Typically set to the FQDN of the host that signed the certificate.
    • <Path To Certificate File>: Full path to the certificate file
and then restart Apache Tomcat
Toolika Dixit
Hello @charlo
Thank you for reaching out to PTC.
Could you please provide me below information in order to assist you further on this case
  • Please confirm ThingWorx version
  • Please confirm MQTT version
  • Please share ThingWorx and MQTT logs
Toolika Dixit
charlo1-VisitorAuthor
Dear PTC,
my ThingWorx version is 9.1.0 (TRIAL)
my MQTT is Eclipse Mosquitto MQTT v5/v3.1.1 broker.
I've revised the log file, but as I hadn't got to turn on SSL, the SSL
problem is not in log files.
The problem is that there is only the SSL enable checkbox, but I can't
configure a CA file.
Carlos
Hello @charlo
Please check this article which explains how to configure  MQTT broker which is using a Self-Signed or Custom Root Certificate
Toolika Dixit
Support
Hi @charlo.
If you have resolved your issue with the help of one of the previous responses, please mark the appropriate one as the Accepted Solution for the benefit of others with the same problem.
--Sharon
