May 30, 2024 6:25 AM UTC
SSO : The request was rejected because the URL contained a potentially malicious String "%25"
Hello Community,
We are trying to enable SSO on Thingworx with AD FS. When we access Thingworx it throw below error message
[L: ERROR] [O: S.c.t.s.a.AuthenticatorExceptionHandler] [I: ] [U: ???] [S: ] [P: ] [T: https-openssl-nio-443-exec-19] [ The request was rejected because the URL contained a potentially malicious String "%25" ]
[L: ERROR] [O: S.c.t.s.a.AuthenticatorExceptionHandler] [I: ] [U: ???] [S: ] [P: ] [T: https-openssl-nio-443-exec-10] [ Error validating SAML message ][ NameID element must be present as part of the Subject in the Response message, please enable it in the IDP configuration ]
[L: ERROR] [O: S.c.t.s.a.AuthenticatorExceptionHandler] [I: ] [U: ???] [S: ] [P: ] [T: https-openssl-nio-443-exec-7] [ Error validating SAML message ][ NameID element must be present as part of the Subject in the Response message, please enable it in the IDP configuration ]
[L: ERROR] [O: S.c.t.s.a.s.ThingworxSSOAuthenticator] [I: ] [U: ???] [S: ] [P: ] [T: https-openssl-nio-443-exec-16] [ Failed to utilize the SSO component for authentication ][ The request was rejected because the URL contained a potentially malicious String "%25" ]
Could someone help me on this
VR
VelkumarAnswer
Jun 3, 2024 10:12 AM UTC
With support of PTC, we managed to fix the issue.
Error Message :
In sso-settings.json, file path was mentioned using backslash "\\" changed to frontslash "//"
Example :
Instead of
"C:\\PTC\\idp-metadata.xml"
use
"C://PTC//idp-metadata.xml"
For error message :
Add NameID in SAML response subject. This should be changed in IDP side
For AD FS refer below link
Authentication Failed: Error validating SAML message : NameID element must be present as part of the Subject in the Response message, please enable it in the IDP configuration - Progress Community
/VR
May 30, 2024 10:18 AM UTC
Hi @Velkumar  Remove special characters "%", ";", "\", "/" from file name
Check documentation  Windchill Help Center > Windchill Fundamentals > Working with Windchill Objects > Object Overview > Special characters
Velkumar19-TanzaniteAuthor
May 30, 2024 10:29 AM UTC
Hi @Surya_Tiwari
I went through this article - CS327941 - Error "The request was rejected because the URL contained a potentially malicious String "%25"" reported in MethodServer.log when donwloading a file from Navigate with SSO enabled (ptc.com)
I think it is not applicable for my use case. Here I'm trying to integrate ADFS and Thingworx. While authentication I'm facing this error message
/VR
Velkumar19-TanzaniteAuthorAnswer
Error Message :
Example :
Instead of
use
For error message :
/VR
Jul 2, 2024 12:37 PM UTC
Hello Velkumar,
   I have a requirement  to enable SSO on Thingworx with AD FS. Do you have any resources to implement this feature.
Jul 4, 2024 4:56 AM UTC
Hi @Prasad_N
Configuring Authentication with AD FS (ptc.com)
/VR
